Brix Plugin
  • #31
    I'll hold you to that post. I heard the same thing from other places, but now I have it in writting
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #32
      just bought the plugin. Quite impressive so far.
      Got just a problem......is there any way to control the uvmap of the "image based color control" indipendently by the one of the bricks? This would be very helpfull for the project I am working on right now.
      Thanks in advance.
      Filippo
      • #33
        Hi Filippo,
        currently you can´t change the uv setting of the bitmap, but we are working on a solution that
        will allow using standard bitmap slots in for the image based color control, which would allow
        to use the uv setting in the bitmap slot itself.
        Best,
        Martin
        BRIX - next generation textures
        www.materialwerk.com
        • #34
          Thanks for your reply,
          I also tried to make a blend material with two different stone colors and to use the brix texture with the image color based at opacity 1 as mask.....but it seems not working. I thought it was a good way....I was wrong!
          Hope to see soon the new improvements! Anyway....great plugin!
          Thanks again.
          F
