how to mass assign a controller?
  • how to mass assign a controller?
    as title says? any script to speed up that operation?
    in my case is for assign orientation constrain controller to a lot of billboard towards single camera
    thanks in advance
    Alessandro
    are all the objects the same thing?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      ehm, what do you mean with same thing?
      I have a lot of poly object (one polygon each), every one is mapped with a different tree image to use them as billboard and I would like to assign them an orientation constrain controller with the orientation target pointing to the same camera
      Something similar to select all the planes then apply the controller to all of them
      Alessandro
        I was thinking if they were the same object you could assign the control and then "clone and align" them
        Chris Jackson
        Shiftmedia
          http://www.scriptspot.com/3ds-max/sc...oller-assigner
          maybe do a search there if this does not work for you
          Two heads are better than one ...
          ....but some head is better than none.....
            thanks a lot Mike, it seems to works wonderfully!!!
            Alessandro
              For the record you should also be able to select the tracks in the curve editor and apply an instanced controller to them too.
              Regards,
              Thorsten
                Cool, never used it, but noticed it before in a similar search...
