3dsmax blinking in Windows 7
  • #16
    did you try setting you graphic preference to classic 7?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Originally posted by JeffG2 View Post
      Anyone find a solution to this?
      I'm on XP64 and after Vray finishes rendering I have to sit through minutes of interface "blinking".
      Since you're on XP64 then it's something different. The blinking problem is exclusive on Vista/7 since the GUI is handled by graphics card. We don't have this issue when we install XPs on the same machines. Your blinking will be probably different then blinking I described earlier
      Yup, tried that, still the same.
      David Slachta
      The Looop CGI
      Shanghai, China
      • #18
        I get this quite a lot too with a varied selection of GFX cards, always happens with very heavy scenes.
        If it's the same problem as I experience, I've found that I can sometimes fix it by clicking the maximise/restore button at the very top right of 3dsMax (you have to catch it between a refresh)...
        Rob
        Uniform | Somewhere
        • #19
          Haha, yea. We discovered that if you right-click this very bottom-right corner area of 3dsmax it will bring up a viewport quality window which freezes the viewport refresh and you can actually set box-mode in the mentioned window which makes it not blinking anymore. But it's quite annoying because you have to click exactly at the time of a refresh.
          Just wondering - are you using ATI cards or nVidia?
          David Slachta
          The Looop CGI
          Shanghai, China
          • #20
            ATI Radeon X1900
            • #21
              Quadro FX 3700, here.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
