modeling problem
  • modeling problem
    How can I model this:
    Any Ideas?
    _________
    sorry for my English
    patiently
    1. Maybe start of with a plane and polys, edit, add polys, edit. etc
    2. Or maybe start with couple of cylinders, add noise modifier, add poly edit, move vertices as needed.
    Kind Regards,
    Morne
      By hand??? extreme idea
      I'm searching for some kind od L-system generator now.
      Maybe I can find something
        Maybe try with onyx tree generator
        Kind Regards,
        Morne
          Beat me to that suggestion!
          Kind Regards,
          Richard Birket
          http://www.blinkimage.com
            Well, if it HAS to be exact, just model with splines and make them renderable/viewable. Then afterwards convert to poly and scale some of the larger branches up by hand.
            LunarStudio Architectural Renderings
            HDRSource HDR & sIBL Libraries
            Lunarlog - LunarStudio and HDRSource Blog
              If your willing to give blender a try It has a script that is called trees from curves in 2.49. it works really well. you draw up your splines (curves) and then apply the script. It creates one continuous connected mesh (all of the branches are connected to the base) that you can then adjust. I used it for the exact same thing you are doing right now.
              val valgardson
              http://www.photorealistic-rendering.com/
                Thanks for the info. Maybe I'll try with Blender - first time
                __________
                  Im sure there is a script on script spot that allows you to draw splines and then it converts them to polys to make tree type shapes...worth doing a search.
                  Regards
                  Steve
                  My Portfolio
                    I know that nPower has some utilities that creates tube like junctions pretty easily. I used it a long while back, huge life saver. It does cost a little bit, so other options may be more affordable, but it is a great toolset to have around in Max!
                    Troy Buckley | Technical Art Director
                    Midwest Studios
                      Could try experimenting with ivy generator without the leaves... for the base. Main trunks you could do by hand.
