Slow to delete
  • Slow to delete
    Is anybody having issues with long delete times in 3ds MAX? When I select a layer and hit delete it takes minutes to delete the data on that layer. I am suing 3ds MAX Design 2011. I am writing this while waiting for a layer to delete
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    Negative. Works fine here... [EDIT] I forgot that I am using 3DSMax 2011, NOT Design 2011. [/EDIT]
    I would strongly consider a reinstall of the software. You seem to be having quite a few strange problems lately. Either that or delete your 3dsmax.ini file and create a new one just in case something got messed up in there.
    Weird!
    Troy Buckley | Technical Art Director
    Midwest Studios
      Happens to me too. I'm using 3dsmax 2011.
      Surrealismo
      https://www.facebook.com/surrrealismo
        Happens to me all the time. Deleting large numbers of objects takes forever and - when deleting very large numbers - may cause crashes (Max 2011 and Max 2010)
        Check my blog
          Same here, wasn't there with max 2009 though...
          Andrian
          _____________________________________
          www.fekta.eu
          Portfolio
          CG Talk
            same for me...
            I miss 2009
            just thinking, might be something to do with undo's?
              Convert the objects to Edit mesh and delete, can be a solution?
              www.francescolegrenzi.com
              VRay - THE COMPLETE GUIDE - The book
              Corona - THE COMPLETE GUIDE - The book
              --- FACEBOOK ---
                good tip, I'll try it.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
