How to create a vac formed head from a plane
  • How to create a vac formed head from a plane
    I need to create a model like this pic to form a head comming out of a plane, I allready have a head does anyone know of a way to shrink wrap a plane on it rather than re-modelling the whole thing?
    I have tried max cloth and reactor cloth but its not going too well.
    Thanks for your help.
    Simon
    Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
    Conform could do the trick:
    - Place a plane in front of the face (you'll need a lot of subdivisions to get good detail)
    - Select the plane and crate a conform object (Crate/Compound/Conform)
    - Pick the face as wrap-to object and better check "Hide Wrap-To Object"
    Most likely you'll need some tweaking but should be a good start.
      Thanks Codi this was the kind of thing I was looking for, I will give it a go.
      Simon
        Shame max 2012 isnt out...it has a tool to do that kind of thing...
        Regards
        Steve
        My Portfolio
          Really I wonder if there will be much in the way of new stuff ive not really looked at it, wont be able to upgrade for a while anyway!
            you can do this very easily in zbrush,
            http://www.pixologic.com/docs/index....ect_Bas-Relief
            import the head
            select the plane tool, draw it in the canvas, go to edit mode, shortcut key, t
            click on convert to 3d button (changes the plane from a parametric object to an edit poly) top of the tools menu
            you have to do this so that you can append this plane later as a subtool, you cannot append the plane when it is a parametric object
            select your head
            draw on the canvas, go into edit mode
            append the plane as a subtool,
            place the plane in front
            select the z project brush and paint the plane on the head
              Thats pretty impressive, ive never used zbrush I must take a look one day, I only have 3 3d studio to do it in, I forgot to mention that part!
              Thanks for your help, I will take a look at zbrush if I can get a demo!
                what tool is that?
                Luke Szeflinski
                :: www.lukx.com cgi
