Clouds
  • Clouds
    How would you simulate cloud shadows? Would a projection map be the best? I would be curious to see how much realism it ads to an exterior scene. has anybody tried?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Somebody was doing great clouds with Vray volumetric fog a while back. They were even sharing the scene file. I believe it rendered quickly and- of course - cast shadows.
    You could map the transparency of an invisible plane and position it above your scene - it would offer more control.
    I think the effect does enhance scenes.
      I remember playing with that, but I never thought the results were all that great. Maybe I can use it just for the shadows.
      http://www.spot3d.com/vray/help/150S...ronmentfog.htm (sample scene)
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        If you strategically painted a mask and do as jeff says it could make the structure stand out against a bland foreground if that is what the issue is...I would still be careful not to make the effect too strong though.
        I think the effect is probably more appropriate for large development renders.
        Ben Steinert
        pb2ae.com
          I've done it on massive site aerials but i'd never bother on something smaller. Difference clouds in photoshop, levels, opacity map, render channel & overlay in ps.
            I've stuck a plane object in the sky with an animated noise pattern on it and it worked quite well with a saved solution. Look here http://www.youtube.com/watch?v=KduVyLdSNZw at 2:18 for an idea. It served its purpose for this animation and could be refined a lot further.
            Kind Regards,
            Richard Birket
            http://www.blinkimage.com
              Wow, very cool idea with the lights going up in the buildings as the description appears.
              Great anim overall!
                you should post it under gallery(tricky) for future reference... I like it a lot, very easy way to understand a project.
                Fernando
                show me the money!!
                  i used the noise/smoke map method on a plane before. works well
                    very nice, i really like the animation! but one question... the sky is stock footage composed in post and the animated noisemap was only for the shadows, am i right? looks like hell of a timeconsuming renderwork if those clouds were cg-animated vray-fog clouds?
                    best regards,
                    christoph.
                    christoph koehler
                    cy architecturevisualization.
                    www.cy-architecture.com
                    visit us on facebook!
                    www.facebook.com/cyarchitecturevisualization
                      veering off topic, but I got to say, Tricky, this is a very nice piece. loved everything about it.
                      Check my blog
