Sun setup memory
  • Sun setup memory
    Is there a way that I can save my sun location per camera view? I typically change my sun location, per camera view, and I have to manually write down the setting for when I have to go back to that view.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    When doing multiple views in one scene i tend to create a layer with the lightsetup and camera per view. So turning on the layer that is named like the cam works fine for me.
    Another option is animating the Camera + sun position, so each frame is one view. This also enables easy batch rendering via simply submitting as a sequence.
    Regards,
    Thorsten
      I do the same as Thorsten. I have a naming convention where any layer prefixed with "1_" means it's toggleable for different setups.
      My convention would make layers like this
      1_Sun.Camera01
      1_Sun.Camera02...
      Only 1 layer of 1_Sun can ever be on a time. This translates to other people understanding relatively easily how I work in the studio.
      -Colin
      Colin Senner
        okay. I guess I didn't think you could have more than one sun system. Sounds easy enough and a no-brainer.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          does the vraysky automatially switch for the all 3 different suns???
          Martin
          http://www.pixelbox.cz
            yes
            I have a sun for each camera and just switch on and off the relevenat sun per camera
            vraysky updates automatically depending on which sun is switched on
            Kind Regards,
            Morne
              You can also use scene states to save a lighting setup for each view.
              Check out my models on 3dOcean
                My vote is for "scene states" as well....I use it all the time!!
                show me the money!!
