Max 2012, now selected splines don't highlight to white in shaded viewports
  • Max 2012, now selected splines don't highlight to white in shaded viewports
    In previous versions of max when I would select any object in a wireframe or shaded/edged viewport, the object turned white to show it's selected. Now in max 2012, if the viewport is shaded, when I select a spline it stays the same color which makes it less obvious that it is selected. It's mostly just an annoyance but I was wondering if there was some setting or system variable to get back the old behavior.
    Funny enough, I just noticed the same thing yesterday; very distracting. I don't know how to restore the old behavior, maybe I'll just enable selection brackets when working with splines.
    Steve Burke
    www.burkestudios.com
      Try enabling - Viewport Configuration >> Visual Style & Appearance >> Selection >> Display Selected with Edged Faces.
      Dan Brew
        how do I get there? I dont see that in my 2012? Do i right click on the little plus in the viewport to get it? Or in preferences? Either way, I dont see it
        EDIT: OH ok nevermind, just had to revert from DirectX and switch to Nitrous
        Kind Regards,
        Morne
          I tried this but same result, it still won't highlight in shaded viewports.
            That's odd. Here are my settings and a couple of shaded viewports showing selected geometry and splines.
Name:	Viewport Config.jpg
            Dan Brew
              [ATTACH=CONFIG]9332[/ATTACH]
              Sorry to change the subject a bit, but I would love to see a render of that room...
              Kind Regards,
              Morne
                You're right it is a bit off topic but as it's you...
Name:	PH-120083-F02-JN01 Client Meeting-001.jpg
                Dan Brew
