Roof Asphalt Shingles
    I couldn't get on the roof, but it was fun trying
    Originally posted by YoyoBoy View Post
    Yeah, check out this work-in-progress Unity-version of ancient Greek farmhouse that I've had in my life forever: http://geoffkornfeld.com/VariUnity/. Every single shingle is a separate element. It is possible to get on the roof and walk around.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      run and jump around back.. fun! My rood is massive, with a lot of valleys... it'll take me a month.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        use http://www.batzal.com/index.php?page=solRD
        Luke Szeflinski
        :: www.lukx.com cgi
          yes. I have that. I will try it and hope the black corners, of the texture, will work instead of clipped geometry, which it can't do.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            hmmm? what clipped geom? create your custom shingles , 5min work:
            Luke Szeflinski
            :: www.lukx.com cgi
            • #21
              I didn't realize you can use a mesh. I'm trying, but it's scattering my mesh into some strange cloud shape.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                why dont you just use the free roof script from digital X models, but then just replace the displacement map with your own custom made shingle map?
                Kind Regards,
                Morne
                • #23
                  I started with that, which works great, but then I have to build a large tillable texture map.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    RTFM !
                    Read the batzal manual what are the rules of creating custom shingle meshes. It need to be 1x1 size and if it's smaller you will create gaps like i did. Remember to change object to mesh (poly won't work)
                    here's my file, just edit the small custom shin I made with what you need. shin.zip
                    Luke Szeflinski
                    :: www.lukx.com cgi
                    • #25
                      http://www.scriptspot.com/3ds-max/sc...o-tools-atiles
                      I'll use this cool script if I had to do this kind of stuff.
                      (Sorry for my bad english)
                      • #26
                        Okay. I read the manual, but it's not working for me. How are you picking your custom mesh? I see yours, and it is what I'm looking for, but I can't reproduce it.
                        RTFM !
                        here's my file, just edit the small custom shin I made with what you need. [ATTACH]9594[/ATTACH]
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          I still dont understand why you just don't use the free roof script with custom displacement. You make just ONE tile with 2 overlapping from the sides, thats it
                          Kind Regards,
                          Morne
                          • #28
                            the script comes standard with 2 tile types and you can give random colour variation. Just pump your own tile type in to get what you want.
                            Kind Regards,
                            Morne
                            • #29
                              I'm trying everything to see what works best.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                this is what's happening to me
                                RTFM !
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
