Possible Memory Issues
  • Possible Memory Issues
    I think I'm seeing a reason for some of my slave issues. It seems that when I increase my dynamic memory above what my slaves like, they don't contribute to the rendering. My main workstation has 24G of ram, but my 5 slaves have 12G. If I increase the dynamic memory to, let's say 8000G, the slaves stay idle, but if I lower the dynamic memory to 4095G, they all chime in. When I say idle, I mean that they don't contribute. They are not idle at all. When I look at the task manager, of the slaves, they are all using 100% of their resources.
    is this typical? What is the rule of thumb when setting up your memory limits? Is it a percentage of the weakest machine?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    What is the operating system of the slaves??
    If it's win7 & your Slaves have 8gb of RAM then set your Dynamic memory limit to 6.2 gb as windows 7 takes quite a lot of RAM [aprox 1.5gb]
      the slaves are xp64, and my main is Win764
      I found this little calculator.
      http://www.cgpinoy.org/t22366-vray-d...culator#375776
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I have assumed it was 80% of your main workstation. I am just wondering what technically happens when you set it to high. I am doing some tests, but it seems like the slaves don't even try when it knows it doesn't have enough resources.
        For en example: when I copy files, and I don't have enough space, it'll tell me and not even try. It seems like the same thing is happening in vray, minus the warning. If this was the case, it would be nice to see something in the vray messages window.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I have the same problem, the main machine have 96GB ram and the dr-slaves have 16GB ram if I set it on dynamic 88GB ram the dr-slaves won't help to render the scene.
          Is there a fix to this or do every computer have the same amount of ram to work properly?
            Sorry this is off topic but whoa, 96GB ram! I'm curious, can you still see benefits of all that ram? can you for instance render an entire planet full off trees without Vray crashing?
            Ville Kiuru
            www.flavors.me/vkiuru
              Actually, you can set the dynamic memory limit to a negative value from MaxScript; in that case, V-Ray will start unloading geometry when the free system RAM falls below that limit. F.e. if you set it to -1000, V-Ray will try start unloading stuff when the there is less than 1000 MB of free system RAM. This may work better across machines with varying specifications.
              Note that the amount of free RAM that you want, is only approximate, so it's not a good idea to set it close too close to 0.
                So, entering the -1000 value directly in the field, in the system rollout, would not work? What's the difference between entering the value from MaxScript and entering it manually, as we are looking at the same value?
                Alain Blanchette
                www.pixistudio.com
                  No, it will be clamped to 0 (which means no limit).
                  If you do that from MaxScript, the negative value will be set correctly. If you do it from the text field, it will be clamped to 0 at the moment. This is because the feature is somewhat experimental and not completely well tested.
                    Well the negative value sounds like a magnificent idea! Hope to see some progress made in this area soon
                    Kind Regards,
                    Morne
                      Testing, but I guess on a scene that does not need it enough.. not much speed gain ( not testing the original DR issue here, but just checking if I can have any performance boost..)
                      Actually slightly slower than imputing the values by hand..?
                      On a 48GB slave system ( which idle seems to run at 3GB..)
                      Setting 44000 manually = rendertime 8:39
                      Setting -4000 via MaxScript = rendertime 8:53 ( prerender script ) or 9:03 ( regular script)
                      I would love the use of a - negative memory value, as lots of our slaves have very different ram levels.
                      Alain Blanchette
                      www.pixistudio.com
                        44000 won't be the same as -4000 tho will it?
                        44000 will always be 44000 but -4000 will be 48000-4000-any RAM used by OS, other applications and non dynamic memory in max (?), so it will always be less.. correct?
                          Sweet!
                          Thank you Vlado! This is going to help us really much.
                          @yyk
                          We need the 96 GB of RAM for extremely large scenes with really large texture-files and displacement-maps
                            Have you tried VRayHDRI with tiled OpenEXR files?
                            • #15
                              sorry for the noob question but, how do I make that maxscript?
                              Surrealismo
                              https://www.facebook.com/surrrealismo
