Backburner and DR jobs
  • Backburner and DR jobs
    Anyone sending vray DR jobs to Backburner?
    Does this work out for you? I'm going to do some in house tests, but I want to know if I am flogging a dead horse before I waste too much time.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    I used to do it all the time before I switched to Deadline. Well worth setting up.
      Yeah DR and backburner works.
      Basically you just run a single server and make sure the DR is set up correctly in the scene file. It's simple but it took me a while to crack for some reason.
        yes as others said
        works fine
        just setup dr as per usual and use 1 backburner slave to send the job to. This way you can also continue working on your pc while another pc (via backburner) actually renders the scene for you via DR to itself and other computers
        Kind Regards,
        Morne
          Yes it works.
          I use it all day and I love it
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            You might want to enable the VrayDrbucket element to check for problem slaves.
              I use it all the time. It's a great way to go. Some common problems people run into but it's all covered in the forum somewhere.
              b
              Brett Simms
              www.heavyartillery.com
              e: brett@heavyartillery.com
                bloody brilliant. thanks chaps.
                Kind Regards,
                Richard Birket
