VMC Script - Vray Material Control
  • VMC Script - Vray Material Control
    The VMC is a powerful maxscript tool that allows you to change the properties of materials or textures in your scene, selection or material editor.
    Version 2 has been completely re-written and now includes:
    • Support for all Vray materials and textures like VrayDirt, VrayHdri etc, native Bitmap texture, Color Correction Map, MultiTexture, MultiScatterTexture and ForestMaterial.
    • A handy subdiv reset for getting old scenes & models where you want them.
    • Improved speed and reliability
    If there is enough support I could release a version to work on just about anything, but we’ll see…
    Download the file here and run the MZP package from 3dsmax’s menu: Maxscript -> Run script or drag it into a 3dsmax viewport.
    Enjoy!
    PS. this post is just in case you missed the v1 thread 5 years ago!
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    Awesome. Thanks
      nice one Olly
        just used it for the first time.. very powerful update. cool!
          BTW, the bitmap output rollout properties is not hooked up yet, I have this working and will release an update shortly.
          My pleasure. If you find it useful, all I ask is that you please consider donating via the thank you button!
            I've just added v2.01, which includes:
            bug fixes
            revised functionality to set standard light vray shadow subdiv properties
            the output properties for bitmap textures now works.
            added bonus features for donators!
              Version 2.1 is now available: http://www.oliverradford.com/3ds-max...erial-control/
              Bug fixes:
              Fixed the long standing “Unknown property: “subdivs” in Free Rectangle.” bug
              Modified features:
              Subdiv reset now applies your BF GI setting (if checked) to all of your RPManager passes if installed.
              New features:
              Hooked up the bitmaptexture functionality. There are now 3 classes you can work on that should cover nearly everything: StandardUVGen for changing blur and tiling etc. StandardTextureOutput for changing clamp and output amounts etc and bitmaptexture for most other stuff like filtering.
              Added an auto update option for the script so you can always be up to date.
              Enjoy!
              Cheers,
              Olly
                Sounds great, but the download button doesn't seem to be working.
                - Geoff
                  Ooops. I guess I didn't click it enough times.
                  - Geoff
                    Great stuff. Essential tool!
                    Alex York
                    Founder of Atelier York - Bespoke Architectural Visualisation
                    www.atelieryork.co.uk
                      I love this script. We are about to upgrade to vray 3. Does it work with vray 3 also?
                        The old version did so I would assume so.
                          Yes, barring a renaming of VRay, it will even work with Vray 4 and beyond.
                            Great news, thanks.
                            • #15
                              Thought you would like to know that I have published version 2.129.
                              You can find out what's new and download the update here: http://www.oliverradford.com/3ds-max...erial-control/
                              Cheers,
                              Olly
