3DS MAX 2013 Bitmap Quality
  • #16
    Originally posted by voltron7 View Post
    Thanks thablanch, that is a real help, quite often...
    edit: update, still great, but note the image must be rgb vs. grayscale. (At least for my max2012)
    Hello! Has anyone been able to make use of the blend_dxsas.fx in Max2014?!?
    It just says, "No Parameters to edit" on almost all of the dx shaders, actually.
    Really need to be able to see the images clearly...might have to revert to 2013.
    • #17
      answer for me
      ...is to use the StandardFX11.fx shader and use the top diffuse map and enable it, too.
      Then it shows pretty blurry, but in configure viewport performance tab, I increased texture maps to 4096 and it is nice and crisp again.
      Wish I had made that change months ago!
      • #18
        The old trick didn't work in 2014. But thanks, this one does!
        Kind Regards,
        Morne
        • #19
          To update this...I think now this works in a vraymaterial's diffuse slot and can skip the whole directX step...
          • #20
            it didnt work for us. Still had to use the directx trick
            Kind Regards,
            Morne
