Cutting multiple boards with a shape
  • Cutting multiple boards with a shape
    I have a bunch of floor boards that I have modelled in a herringbone pattern. They are simple single rectangular polys (1 poly per board) with a uvw map on them. Each one is instanced and then moved into position.
    I now want to 'cut' the boards to fit my walls. Is there any good way I can simply draw a shape in the top viewport that traces out all of my walls, and use this to cut all my instanced floor boards? I had hoped 'shapemerge' might work, but it seems not. I think that only works with selecting single objects.
    Any tips?Click image for larger version
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    if your boards are how you like them cant you just convert to editable poly and attach them all to be 1 object to cut?
      boolean (intersection) them as one piece would work...maybe not the way you want but that is how i have done 3d roof tiles.
      mh
        If it's one poly object I would just use quickslice.
        /Thomas
        www.suurland.com
        www.cg-source.com
        www.hdri-locations.com
          If you really want to keep them all as separate objects. I would select all of them and add a slice modifier, this would be an instance on all the objects and the object would become a reference.
          Repeat for each wall.
          Gavin Jeoffreys
          Freelance 3D Generalist
            I suppose I just wanted flexibility in case I add detail at some future point. Converting to single poly may be much simpler. Thanks.
            Kind Regards,
            Richard Birket
              Yes - this is the route I was thinking of taking. It just becomes a pain selecting only the planks that need cutting.
              Kind Regards,
              Richard Birket
