Backburner node issue all of a sudden !
  • Backburner node issue all of a sudden !
    For some reason half way through a job that is about 1200 frames long the render manager keeps stopping with this error: An Unexpected Exception has occurred in the Network Render and it is terminating : The pipe has been ended : 109 3dsmax adaptor error
    The servers report this message: Adaptor reported unexpected code -2 for - (and then a lot more text which I cannot copy from the server info).
    If I restart all the nodes they seem to be fine and start rendering. Then they stop again shortly after.
    I've not installed any new software on any of the nodes etc.
    Does anyone have any ideas as I need to render a lot of animations out...
    Regards
    Steve
    My Portfolio
    same issu here. BB 2014 is always terminating with error 109!
    have installed BB 2012 again, nor I test it with max 2014.
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
      Try disabling antyvirus/firewall/spyware... They might had an auto update and now are breaking stuff
        disabling spyware. I have to found it first...
        thanks
        themaxxer
        Pixelschmiede GmbH
          It turned out that it was a problem with the job sent to backburner. I sent another job using a similar setup and it rendered fine. I did also have another problem when trying to render just some elements on my main workstation. A dreamscape sea object kept crashing the system until I deleted it and imported it from an earlier scene. Render was fine then so not sure why I suddenly had crashes with dreamscape.
          I would check any plugins you are using and maybe re-create them or import from an earlier scene. Also, I guess do the same with objects etc. I guess firewalls, virus progs could be the issue but I've never found them to be in all the years I've been using vray/max etc
          Regards
          Steve
          My Portfolio
            This error has come back again for an entirely different job. I actually updated all my render nodes recently to windows 7 from XP as I thought this might be the problem but now it shows wasn't the reason behind this error. I've disabled firewall and virus and still no luck. The strange thing is that the node that acts as a render manager also has a render server on it and works fine. My main system works fine with it but the other 3 nodes all throw this error. I did have one specific node throw an additional error (attached):
            Regards
            Steve
            My Portfolio
              okay. I think I've found the issue. I forgot that I installed max 2012 on the render nodes in question after I installed max 2014. This install reverted backburner to 2012 which seems to be the reason behind this problem. All working now that backburner is v2014 on all systems.
              Regards
              Steve
              My Portfolio
                Ah, the joys of renderfarm management.
                Glad you got it sorted!
                Troy Buckley | Technical Art Director
                Midwest Studios
