UVW Maps
  • UVW Maps
    There has to be a way! let's say I have 100 fence pickets. Each picket I want to apply a UVW to fit each picket, and not all the pickets as one large selection.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    scale it to the general size you want, press make unique and then use the mass randomizer script to randomly offset them.
    If it's a map customized for the picket and doesn't need to be offset you should have used instances.
      Have a look on scriptspot Bobby as I am sure I saw I script there to do do just what you want.
        If they are instanced, just select one picket and not all, apply an UVW modifier and will fit to those picket but is also applied correctly to all other instances.
          Check "Use pivot" in the modifier list and then apply the UVW map.
            Wow! I never heard of this "Use Pivot Points" thing. How long have we had that?
            - Geoff
              Same! Love finding new (but probably super old) tricks like this
                Where is "use pivot", I didn't see it.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  If you have more than one object selected, you will see it at the top of the modifier drop-down list. When you have only one object selected it is grayed out.
                  - Geoff
                    Hmm. That was a new one for me too. What is its function.....can't find anything in the docs.
                    Signing out,
                    Christian
                      screen shot please, I can't find it.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Honestly I've never seen it before either until it was mentioned in this thread.
                        Brendan Coyle | www.brendancoyle.com
                          okay, thanks. I wasn't looking there.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            http://docs.autodesk.com/3DSMAX/16/E...ber=d30e229838
                            www.seraph3d.com
                            Senior Generalist
                            Industrial Light & Magic
                            Environment Creation Tutorial
                            Environment Lighting Tutorial
                            • #15
                              Me too...and after looking into the manual I've had difficulties to find it...
                              The knowledge is a neverending story...
