Nexus Pendent Light
Nexus Pendent Light
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
here is the photo - I might have to model it, but I would rather buy it. http://www.aboutspace.net.au/nexus.html
I do own this, so it might work for me, but I know I saw a better one somewhere.
http://www.interovisuals.com/product...ary-mesh-lightBobby Parker
phone: 2188206812
- Windows 11 Pro
You can get that outer pattern by creating a low poly geosphere, adding a meshsmooth with 1 iteration, converting to edit poly and using the graphite selection tools to first select all the vertices with 5 edges, doing a ctrl-del to remove them, then the 4 sided, then select the 2 sided verts, invert it and remove those. You can then go to poly selection, select the 5-sided polys, invert that, convert selection to vertices and weld with a huge threshold. I think that should get you most of the way there.
I'll try it, thanks!
Originally posted by cubiclegangster View PostYou can get that outer pattern by creating a low poly geosphere, adding a meshsmooth with 1 iteration, converting to edit poly and using the graphite selection tools to first select all the vertices with 5 edges, doing a ctrl-del to remove them, then the 4 sided, then select the 2 sided verts, invert it and remove those. You can then go to poly selection, select the 5-sided polys, invert that, convert selection to vertices and weld with a huge threshold. I think that should get you most of the way there.Bobby Parker
phone: 2188206812
- Windows 11 Pro
This looks close http://www.designconnected.com/light...23/lighting_c5Bobby Parker
phone: 2188206812
- Windows 11 Pro
Actually I almost purchased that one, but I ended up with another one.Originally posted by new.ages View PostBobby Parker
phone: 2188206812
- Windows 11 Pro
