To all NUKE users: NUKE not utilising HW well enough - please help
the beauty pass is fully covered with pixels but there are many layers with mask which should be clipped no?
The data window is the same for all channels, so if the image is fully covered with render data, the data window will be the same as the image. So not much luck here then...
a bug fixes about zdefocus on windows that was single threaded, maybe you're using an older version?
Try removing that zdefocus and places some other node and look at the rendertimes.
