Reset MAX
  • Reset MAX
    A strange thing happened to me, by chance, and I thought I would share. I was fixing an error I was having in MAX, so I renamed MAX's ENU folder (:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3ds maxdesign\2014 - 64bit\ENU), which solved my issue, but it also must have done something else. I stopped a render that had an estimated 8hrs to render. I was going to run it over night, so the render time was no big deal, but..! I am rendering it again, after letting MAX re-create the ENU folder, and it now is rendering in 2 1/2 hrs. So. it might be a fluke, but it might be something to look into.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    in the new ENU, are u using Solidrocks?
    Martin
    http://www.pixelbox.cz
      you have to also bear in mind that reseting ENU also resets all the paths and such.
      may be it might be the paths too??
      BTW:
      i reset ENU almost 2 times a day
      for that reason i have created different MAX ENU setups and everytime max craps out, i just simply rewrite the ENU with a saved one
      Martin
        I don't have anything in my ENU now, except the default. I did back up my scripts menu, so I'll copy that back over.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
