Displacement Roof Surfaces
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Hmmm... I re installed the plugin and not it is working. I would love to see this developed more, what will it takeBobby Parker
phone: 2188206812
- Windows 11 Pro
hello.
Here in the office we have many problems with the import of models from REVIT. Apparently the way as polygons making structure creates a great internal confusion on scales. Since the size of maps to the internal dimensions of the polygon.
IN fact there are times when the scenes respond poorly to the lights. And not only with Vray but with other engines.
It's like becoming the Revit model with different scales, but internally polygons say otherwise. It dont really strange.
make a new scene and temporarily change your SYSTEM units to cm
import your "clean" planes
run the script
save your temp scene
open your actual scene with your usual units and merge in the roof from the temp scene
usually works for meKind Regards,
Morne
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Who do I have to pay to get an updated version? It hasn't been updated since 2010. It's an awesome script and I need it for the roof edges. I might install MAX 2016 just to use it again.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Alrighty, then.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Vizioen View PostLol who still uses this in 2018.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Yes, I use RC for roofs other than asphalt. I have clients that I have had for a decade that wants to see the roofs I do with the displacement script. I have tried RC for them, but they just don't turn out the same. Plus, with the script, I can do the most elaborate asphalts roofs in a couple minutes. If I am the only one asking for it to be updated that is probably why it hasn't been updated in 8 years.Bobby Parker
phone: 2188206812
- Windows 11 Pro
