Displacement Roof Surfaces
  • Displacement Roof Surfaces
    Do you know what would cause this error? It's an imported Revit model, but I cleaned it up into simple planes.
ID:	879590 Click image for larger version
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hmmm... I re installed the plugin and not it is working. I would love to see this developed more, what will it take
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      hello.
      Here in the office we have many problems with the import of models from REVIT. Apparently the way as polygons making structure creates a great internal confusion on scales. Since the size of maps to the internal dimensions of the polygon.
      IN fact there are times when the scenes respond poorly to the lights. And not only with Vray but with other engines.
      It's like becoming the Revit model with different scales, but internally polygons say otherwise. It dont really strange.
        make a new scene and temporarily change your SYSTEM units to cm
        import your "clean" planes
        run the script
        save your temp scene
        open your actual scene with your usual units and merge in the roof from the temp scene
        usually works for me
        Kind Regards,
        Morne
          Hi
          What script?
            http://www.scriptspot.com/3ds-max/sc...-roof-surfaces
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Who do I have to pay to get an updated version? It hasn't been updated since 2010 . It's an awesome script and I need it for the roof edges. I might install MAX 2016 just to use it again.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                be a man and model the roof tiles individually..... I'm not a robot
                  Alrighty, then.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Lol who still uses this in 2018.
                    A.
                    www.digitaltwins.be
                      Nobody, cause it hasn't worked for a couple years. To me, it was the easiest and best way to do 90% of my roofs.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Railclone instead?
                          Yes, I use RC for roofs other than asphalt. I have clients that I have had for a decade that wants to see the roofs I do with the displacement script. I have tried RC for them, but they just don't turn out the same. Plus, with the script, I can do the most elaborate asphalts roofs in a couple minutes. If I am the only one asking for it to be updated that is probably why it hasn't been updated in 8 years.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
