Help me create a material
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
I suppose the basic metal shader shouldn't be a problem for you, so the challenge is getting the Bump map.
A quick idea on how to do this would be a couple of stretched out noise maps multiplied over each other, rotated at 45 and -45 degrees.
Completely procedural and very adjustable. To tweak the length and density of the scratches, adjust noise thresholds and tiling amount. If you want to take it further - add a few more layers with smaller/larger scratches, use large scale noise as layer masks, get some scratches with less depth by using lower opacity on a layer, etc. sky's the limit
Check the link for mat file.
http://viscorbel.com/wp-content/uploads/crosshatch.zipLast edited by viscorbel; 27-05-2014, 06:22 AM.
Originally posted by viscorbel View PostI suppose the basic metal shader shouldn't be a problem for you, so the challenge is getting the Bump map.
Completely procedural and very adjustable. to tweak the length and density of the scratches, adjust noise thresholds and tiling amount...[ATTACH=CONFIG]19686[/ATTACH]
Let me look at yours and see what I have done wrong.Kind Regards,
Richard Birket
Here's a bitmap-based approach, Richard. The map I'm using is not detailed or accurate enough really, but it shows one way to approach the material.
You might consider photographing your (assuming it's your) sample piece of metal in a very even light. A little work in Pshop and you may very well end up with an excellent and accurate map.
Hope this helps some,
-Alan
CrosshatchedMetal.zipLast edited by Alan Iglesias; 03-06-2014, 05:56 PM.
