Now available on the Autodesk Application Manager (if you don't see it just do a 'check now') or download them here:
From the readme file, the following issues were addressed:
- MAXX-18050 The PhysX plug-in would cause a program error.
- MAXX-17998 The MAXScript interface to the Skin modifier's Envelope feature was incorrect.
- MAXX-17968 Backburner: Split Scan Lines did not work when rendering a Camera view.
- MAXX-17895 Save File As: The + button was hidden in the Japanese interface.
- MAXX-17866 Frozen objects could be selected in viewports.
- MAXX-17727 ShaderFX materials weren't transferred properly when using the FBX format.
- MAXX-17725 OpenSSL has been upgraded to correct a security issue.
- MAXX-17680 Wrong decimal separators have been fixed.
- MAXX-17669 FBX for 3ds Max plug-in presets were missing.
- MAXX-17631 The file crashMax.dlu was built into the wrong folder.
- MAXX-17550 ShaderFX nodes needed to be copied to user settings.
- MAXX-17434 Base State material was resetting.
- MAXX-17431 The mental ray renderer would hang when rendering an empty scene in an orthographic view.
- MAXX-17342 It was impossible to rename a layer from the Layer Toolbar.
- MAXX-17282 Opening the Layer Manager was slow when many objects were on a layer.
- MAXX-17263 ActiveShade would cause a buffer overflow.
- MAXX-17236 Customer Error Report: An issue with ChamferedFaces has been fixed.
- MAXX-17235 Customer Error Report: A core issue with object display has been fixed.
- MAXX-17210 The Crossing option for Window/Crossing selection was not working.
- MAXX-17172 The Cloth and Garment Maker modifiers were not localized.
- MAXX-17152 Scripting a Dummy object was not working.
- MAXX-17101 Viewport focal-point sampling was not working.
- MAXX-17097 Rendering with the mental ray renderer would cause a program error.
- MAXX-17036 Backburner 2015 running as a service would cause an "adapter error."
- MAXX-17024 Rendering an area would not appear in the Rendered Frame window.
- MAXX-16957 A change to Vertex Crease on the Ribbon would not update on the Editable Poly control panel.
- MAXX-16813 Composite map: Tile offset was not working in Nitrous viewports.
- MAXX-16798 The movie list on the Welcome Screen contained a nonsense string.
- MAXX-16796 Nitrous viewports have been upgraded to support up to eight Composite map layers.
- MAXX-16767 Opening Layer Explorer with 1,000 layers was slow.
- MAXX-16766 FBX import: Normals on skinned meshes were being ignored.
- MAXX-16678 The installer for the plug-ins to exchange data with Adobe After Effects did not install the right files.
- MAXX-16468 The animated Tours on the Welcome Screen were not localized.
- MAXX-16407 Display By Layer was not correctly displaying layer properties.
- MAXX-16387 Customer Error Report: Error opening certain files. This has been fixed.
- MAXX-16241 Scene Explorer would generate a MAXScript error exception when Esc was pressed.
- MAXX-16140 Scene Explorer: The object list would not resort when a file was renamed.
- MAXX-15964 Workspaces wouldn't load mnux.cfg files.
- MAXX-11987 Customer Error Report: An error in Skin has been fixed.
- MAXX-11011 CAT: A rig arm would not stretch with IK.
