Ribbon
  • Ribbon
    Hi guys,
    I'm using loft and twist along a path to create a twisted ribbon. Problem is that I can't seem to get the ribbon to resemble the attached example. I'm assuming this is because the shape is central and needs to be off center. Any ideas how to get this working ?
ID:	881207Click image for larger version
    Regards
    Steve
    My Portfolio
    id imagine that moving the axis of the source spline to be at the centre of rotation would do it. or, can you not just put a number of control shapes along the path then transform them off-axis to taste after?
      Looks to me that the ribbon in the org pic is starting on the lower left and flows slightly away from the camera then when it bends, the bend is toward the the camera and exits on the right. your example looks to just flow from left to right.
      Cheers,
      -dave
      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
        I'll see if I can add some more shapes at specific points...Cheers
        Regards
        Steve
        My Portfolio
          did you try the method by super gnu? looks like the twist is off axis
            Haven't tried it yet..I will be later on.
            Regards
            Steve
            My Portfolio
              I can't seem to work out how to do this. Something that should be so simple..damnit !
              Regards
              Steve
              My Portfolio
                I think your loft path needs to be a stretched out helix.
                Dan Brew
                  I was thinking exactly the same thing last night. I don't think there is an easy way to create a helix type curve along that path though. Maybe I can path deform a helix spline along the sections that need it and then attach those to the main spline.
                  Regards
                  Steve
                  My Portfolio
                    Use a path deform modifier. It does exactly this.
                    Dan Brew
