I just purchased a 13" MACBOOK Air. I bought it to do some Photoshop, but the screen isn't any better than my 14" Chromebook. I tried to edit a render and it looked bad, so I thought the render was bad. I ended up editing it on my desktop, so it wasn't the render. My question is, how much better is the MACBOOK Pro Retina? I know my iPad Air Retina is awesome. The MACBOOK Pro Retina is $300 more, but is it worth it?
Macbook
Macbook
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Images look awesome on the iPad Air, so I am hoping it's just as good on the MABOOK Pro with Retina. I watched a podcast about the wide gamma range that the retina has, which makes if far superior to any other viewing device. Some now have higher resolutions, but the image still isn't as good.Bobby Parker
phone: 2188206812
- Windows 11 Pro
In general language wide gamut will usually be used to refer to displays that are roughly equal to 98% of AdobeRGB and up. The MacBook Retinas roughly display the gamut of sRGB, and iPad mini's have an even smaller gamut. IMO there is nothing really wrong with working in sRGB color space but sRGB is not wide gamut. I do a fair amount of work on an older cinema display which is only sRGB.
....but I will stick to my earlier statement. Professional color or Photoshop work should never be done on a laptop display. Never. Plug the laptop into an actual monitor of decent color quality and calibrate that display with spectrometer to do color work.
The MacBook Air just looks low resolution, bit it is 1440 x 900 at 128 ppi. The retina is 2560 z 1600 at 227 ppi. I guess the Air is good, but nothing better than others.
Originally posted by crazy homeless guy View PostCan you describe why the image looks bad? It may just be a matter of color space and not a wide gamut issue. Typically Apple does a very good job of having their displays tuned to 6500k color space off the bat (maybe even a touch warmer than that.)Bobby Parker
phone: 2188206812
- Windows 11 Pro
So colors look fine the problem is with how sharp the image looks on the screen.... Not a lot you can do about that until better hardware comes out.
I am curious if you are working solely in OSx or are you running Windows/Max. I have head that Max is a joke on high PPI screens.
Originally posted by glorybound View PostThe MacBook Air just looks low resolution, bit it is 1440 x 900 at 128 ppi. The retina is 2560 z 1600 at 227 ppi. I guess the Air is good, but nothing better than others.
So far, I only installed Photoshop. If I go to the Pro, I'll probably install MAX, too. The Pro retina has 8GB of RAM, but it doesn't have a solid state drive, and it has a DVD drive. And, if I remember correct, it's only a 256 GB drive. The non-pro retina has a solid state 128 Gb drive. The non-retina pro is the same cost as the Air.
Originally posted by crazy homeless guy View PostSo colors look fine the problem is with how sharp the image looks on the screen.... Not a lot you can do about that until better hardware comes out.
I am curious if you are working solely in OSx or are you running Windows/Max. I have head that Max is a joke on high PPI screens.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I would Google and see if it actually only supports 8gb of RAM. I have 16gb's in my 2011 Pro even though the specs say it only supports 8gb. Mine also came with a mechanical main drive. I bought a 256 solid state to use as the main drive and then removed the DVD and put in a drive caddy to house the mechanical drive it came with.
.....you might want to check to see if you can take the MacBook Retina apart though. The old Pro's had ~12 screws on the bottom so access to its internals were easy.
Originally posted by crazy homeless guy View PostI would Google and see if it actually only supports 8gb of RAM. I have 16gb's in my 2011 Pro even though the specs say it only supports 8gb. Mine also came with a mechanical main drive. I bought a 256 solid state to use as the main drive and then removed the DVD and put in a drive caddy to house the mechanical drive it came with.
.....you might want to check to see if you can take the MacBook Retina apart though. The old Pro's had ~12 screws on the bottom so access to its internals were easy.Cheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
I am hesitant on some of the "desktop" replacement laptops as I believe a laptop should be reasonably lightweight and have refinement to the design so that it looks good. I saw one MSI model last year that didn't look to bad but I can't remember the name of it. If I were going to buy today I might go for the QHD+ Touch version of the laptop at the link below as long as I can change the green backlight color. If not that could be a deal breaker for me. The specs look good to me though I wouldn't mind having more than 16gb of RAM and at least a 15" screen.
It actually looks very similar to my MB-Pro but in a matte black finish.
http://www.razerzone.com/gaming-systems/razer-blade
Originally posted by crazy homeless guy View PostI am hesitant on some of the "desktop" replacement laptops as I believe a laptop should be reasonably lightweight and have refinement to the design so that it looks good. I saw one MSI model last year that didn't look to bad but I can't remember the name of it. If I were going to buy today I might go for the QHD+ Touch version of the laptop at the link below as long as I can change the green backlight color. If not that could be a deal breaker for me. The specs look good to me though I wouldn't mind having more than 16gb of RAM and at least a 15" screen.
-=edit=- While I dont mind the green back lighting on the KB the one deal breaker after looking closer at it is the only video out is an HDMI which Ive found can have a nasty lag, if it had a display port out then thats a whole different story.Last edited by Syclone1; 04-02-2015, 04:07 PM.Cheers,
-dave
That does look nice. I purchased one of these a few years ago and it's now a boat anchor; never worked right. It was heavy, ran hot, and crashed often. It was so big it really was a desktop, which defeated the purpose.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Syclone1 View Post-=edit=- While I dont mind the green back lighting on the KB the one deal breaker after looking closer at it is the only video out is an HDMI which Ive found can have a nasty lag, if it had a display port out then thats a whole different story.
Lag while gaming or lag in general?
