UVW Map question
  • UVW Map question
    I have a plane with a UVW Map attached, set for Planar and 8x8 for Length and Width. The carpet weave looks pretty believable near the product, but where it comes closer to the camera, it looks abnormally large (IMO). Is there any trick to making it look more natural with respect to size? The material is just a diffuse image with a bump map. Would VRay 2D displacement help?
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    I would use displacement or at least a normal map for the carpet.
    show me the money!!
      I usually reduce the filtering to 0.1 for carpets, that way you can make the UVW size even smaller so it looks good in foreground and with reduced filtering it won't be so blurry at the back.
        By reducing filtering, are you talking about BRDF Softness or Diffuse roughness?
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          I think he means reduce the blur of your bitmap texture of the carpet. Default is 1.0
          Right click on the spinner next to it to make it 0.1
          Kind Regards,
          Morne
            Yes, exactly the blur amount from 1.0 (default) I usually change it to 0.1 so it looks sharper in the background. It is located under coordinates tag in the bitmap settings, where you can rotate, mirror or tile your bitmap.
