AXYZ People
AXYZ People
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Normal map 100, so I turned it down to 30; I'll let you know.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostNormal map 100, so I turned it down to 30; I'll let you know.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Originally posted by Neilg View Postthat wont fix it, it'll just make everything to do with it less visible. leave it on 100 and actually solve the problem.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Neilg View Postdid you check the gamma? did you take a screenshot of the material setup?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I turned the bump off and it solved the issue. I'll post a screenshot of the material setup when the render is done.Bobby Parker
phone: 2188206812
- Windows 11 Pro
it could well be some funky gamma problem, but it also looks like an issue i had when a bump map was turned up waay too high.. it was causing the normals of the geometry to become so distorted they were showing light from the other side of the object. or something. i dont remember exactly.. it was years ago.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby,
You have a max "normal bump" map nested inside a Vraynormal bump map.
