AXYZ People
  • #16
    I know, that's how it came. I removed it and started over; it's working now.
    Originally posted by jacksc02 View Post
    Bobby,
    You have a max "normal bump" map nested inside a Vraynormal bump map.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      I got some feedback from AXYZ
      Are you using gamma 2.2.?
      The problem you are having is probably due to the set up of the normal maps for gamma 2.2.
      Max is not very clever and it is also correcting gamma on normal maps.
      What you can do is:
      Open the normal map and in “Output” add 2,2 in “output amount” spin box:
      This will fix the problem with gamma corrected normal maps.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #18
        Thx, Had this problem for a while too
        www.bpositive.dk
        • #19
          What you can do is:
          Hello,
          Interesting, I was wondering too where this problem could come from ... now, it's time to make a little script to change this automatically for all characters !
          Nicolas Caplat
          www.intangibles.fr
          • #20
            I said this exact thing in the second post and you decided it wasnt that and you'd just turn it off instead.
            • #21
              Yep, you called it.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                ahhh thank you! We've had this issue with axyz people too. I've been turning off the bump as a quick fix. Thanks for posting the solution!
