UVW Unwrap
  • UVW Unwrap
    I have a funky brick ledge, so I am trying to unwrap it. All works, but when I go to use the texture, that I painted in PS, it doesn't fit. Shouldn't it just fit?
    I have the poly, and then I put a UVW Unwrapper on it. When I save the image out, I open it up in PS and paint it. Once I do that I apply that texture to the poly's diffuse material.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    it should fit, yes. how did you do the unwrapping?
      I pick the wall, apply an uvw Unwrap modifier, render it out from the UVW Unwrap diolog, open it up in PS and paint on it. Once done I do nothing with the modifier; I add the map to the diffused slot of the material.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        so it's just a flat plane? try to load the map you painted in the edit uvws dialog and see how it matches the geometry, you can try adjust it manually from there if it doesn't fit.
          Can you print screen what the UVW editor looks like and the texture in the object in the viewport?
          MDI Digital
          moonjam
