max 2016 strange problem when grouping objects
  • max 2016 strange problem when grouping objects
    Create object, mirror it with instance and try to group ! It's falling apart. Oh and when you ungroup it it's going back to it's correct place
    here's what happens: https://www.dropbox.com/s/hf6mbso46e...group.mp4?dl=0
    Anyone else have it?!
    Luke Szeflinski
    :: www.lukx.com cgi
    Tried as in your video and it works normally here... Max 2016 + SP1
    Good luck
    http://www.3dna.be
      for me the same, comes with SP2 !
      also for existing groups (build in previous SP) you cannot detach or ungroup.group elements get mirrored in all axis over the pivot...
      THAT IS A MASSIVE PROBLEM
        Yeah I'm also on SP2 so I guess it's SP2 problem if Chris is okay on his SP1 . I'm also using wacom tablet and with assigned middle button for pen button to rotate the view with alt It's sometimes doesn't work and I have to Z object and then it works again.
        Luke Szeflinski
        :: www.lukx.com cgi
          Yup ok in sp1.. Gonna stick with it
          Autodesk... seriously
          http://www.3dna.be
            Yeah can confirm that , on SP1 it is ok.
            Available for remote work.
            My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
              Well, I've just linked an object in SP2 and it immediately inherited the scale of the parent, which is obviously not good!
              I'm guessing this is all part of the same problem.
              MDI Digital
              moonjam
                I just ran into this grouping problem yesterday in sp2 - drove me bat shit crazy. So then I thought I would just settle with parenting dummy objects as a workaround - Nope
                Here's what happens
                  would be good if you all report the bug to autodesk and maybe post your examples.
                  i reported over help-speak back-report a problem.dont know if it´s the most effectiv way
                  we think of deinstalling sp2...first time in years
                  anyone idea if there maybe problems after deinstalling a SP ??
                    I've uninstalled SP2 with no problems so far. It took its sweet time though, took 40 minutes on one of the machines!
                    I've only ever reported bugs as a Beta tester. Do you know how/where to submit bug reports to Autodesk? I've looked but keep finding dead ends.
                    MDI Digital
                    moonjam
                      Also getting this problem trying to prep a car in schematic view, break links and parts move all over the place, increments of 90 degree's, and scaling, 2016 sp2
                      Try the exact same process in 2014 and all is good! Very strange for a bug, thought I had a setting wrong, or autodesk changed something
                        directly in 3dsmax-help menu
                        this is what you get back:
                        Thank you for sending your bug report or feature enhancement request.
                        Your report has been entered in our database as:
                        BSPR-22861 MASSIVE group problem with SP2!
                        We regret we cannot respond directly to all bug reports and feature enhancement requests we receive, but all reports are carefully logged and tracked. If you ever require more information on this bug report or feature request, please refer to it using the number indicated above.
                        We would like to take this opportunity to remind you that if you have a valid Subscription with Gold Support contract you may ask questions or get help with problems via the Autodesk Subscription Center in the Support section of the Autodesk website at:
                        http://www.autodesk.com
                          Fantastic, thanks Thomes!
                          MDI Digital
                          moonjam
                            Same Here, Sp2..
                            Regards
                            Fernando
                            http://reflectgraphics.com/
                              Keep reporting it!
