Multi-Threading
  • #31
    Try starting DR server and enable DR. Do you see 72 buckets?
    You can also try cinebench 15 to test if both processors are working if you get score above 4k both are working.
    What is the model of motherboard you have?
    • #32
      Number of processors 2
      Number of threads 72
      APICs
      Processor 0
      -- Core 0
      -- Thread 0 0
      -- Thread 1 1
      -- Core 1
      -- Thread 0 2
      -- Thread 1 3
      -- Core 2
      -- Thread 0 4
      -- Thread 1 5
      -- Core 3
      -- Thread 0 6
      -- Thread 1 7
      -- Core 4
      -- Thread 0 8
      -- Thread 1 9
      -- Core 8
      -- Thread 0 16
      -- Thread 1 17
      -- Core 9
      -- Thread 0 18
      -- Thread 1 19
      -- Core 10
      -- Thread 0 20
      -- Thread 1 21
      -- Core 11
      -- Thread 0 22
      -- Thread 1 23
      -- Core 16
      -- Thread 0 32
      -- Thread 1 33
      -- Core 17
      -- Thread 0 34
      -- Thread 1 35
      -- Core 18
      -- Thread 0 36
      -- Thread 1 37
      -- Core 19
      -- Thread 0 38
      -- Thread 1 39
      -- Core 20
      -- Thread 0 40
      -- Thread 1 41
      -- Core 24
      -- Thread 0 48
      -- Thread 1 49
      -- Core 25
      -- Thread 0 50
      -- Thread 1 51
      -- Core 26
      -- Thread 0 52
      -- Thread 1 53
      -- Core 27
      -- Thread 0 54
      -- Thread 1 55
      Processor 1
      -- Core 0
      -- Thread 0 64
      -- Thread 1 65
      -- Core 1
      -- Thread 0 66
      -- Thread 1 67
      -- Core 2
      -- Thread 0 68
      -- Thread 1 69
      -- Core 3
      -- Thread 0 70
      -- Thread 1 71
      -- Core 4
      -- Thread 0 72
      -- Thread 1 73
      -- Core 8
      -- Thread 0 80
      -- Thread 1 81
      -- Core 9
      -- Thread 0 82
      -- Thread 1 83
      -- Core 10
      -- Thread 0 84
      -- Thread 1 85
      -- Core 11
      -- Thread 0 86
      -- Thread 1 87
      -- Core 16
      -- Thread 0 96
      -- Thread 1 97
      -- Core 17
      -- Thread 0 98
      -- Thread 1 99
      -- Core 18
      -- Thread 0 100
      -- Thread 1 101
      -- Core 19
      -- Thread 0 102
      -- Thread 1 103
      -- Core 20
      -- Thread 0 104
      -- Thread 1 105
      -- Core 24
      -- Thread 0 112
      -- Thread 1 113
      -- Core 25
      -- Thread 0 114
      -- Thread 1 115
      -- Core 26
      -- Thread 0 116
      -- Thread 1 117
      -- Core 27
      -- Thread 0 118
      -- Thread 1 119
      Timers
      ACPI timer 3.580 MHz
      HPET timer 14.318 MHz
      Perf timer 2.241 MHz
      Sys timer 1.000 KHz
      Processors Information
      Processor 1 ID = 0
      Number of cores 18 (max 32)
      Number of threads 36 (max 64)
      Name Intel Xeon E5 2699 v3
      Codename Haswell-E/EP
      Specification Intel(R) Xeon(R) CPU E5-2696 v3 @ 2.30GHz
      Package (platform ID) Socket 2011 LGA (0x0)
      CPUID 6.F.2
      Extended CPUID 6.3F
      Core Stepping M0
      Technology 22 nm
      TDP Limit 145.0 Watts
      Tjmax 80.0 °C
      Core Speed 1197.1 MHz
      Multiplier x Bus Speed 12.0 x 99.8 MHz
      Stock frequency 2300 MHz
      Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
      L1 Data cache 18 x 32 KBytes, 8-way set associative, 64-byte line size
      L1 Instruction cache 18 x 32 KBytes, 8-way set associative, 64-byte line size
      L2 cache 18 x 256 KBytes, 8-way set associative, 64-byte line size
      L3 cache 45 MBytes, 20-way set associative, 64-byte line size
      FID/VID Control yes
      Turbo Mode supported, enabled
      Max non-turbo ratio 23x
      Max turbo ratio 28x
      Max efficiency ratio 12x
      Max Power 290 Watts
      Min Power 69 Watts
      O/C bins none
      Ratio 1 core 38x
      Ratio 2 cores 38x
      Ratio 3 cores 36x
      Ratio 4 cores 35x
      Ratio 5 cores 34x
      Ratio 6 cores 33x
      Ratio 7 cores 32x
      Ratio 8 cores 31x
      Ratio 9 cores 30x
      Ratio 10 cores 29x
      Ratio 11 cores 28x
      Ratio 12 cores 28x
      Ratio 13 cores 28x
      Ratio 14 cores 28x
      Ratio 15 cores 28x
      Ratio 16 cores 28x
      Ratio 17 cores 28x
      Ratio 18 cores 28x
      TSC 2294.7 MHz
      APERF 1197.2 MHz
      MPERF 2294.7 MHz
      IA Voltage Mode PCU adaptive
      IA Voltage Offset 0 mV
      GT Voltage Mode PCU adaptive
      GT Voltage Offset 0 mV
      LLC/Ring Voltage Mode PCU adaptive
      LLC/Ring Voltage Offset 0 mV
      Agent Voltage Mode PCU adaptive
      Agent Voltage Offset 0 mV
      Temperature 0 50°C (122°F) [0x1E] (Core #0)
      Temperature 1 53°C (127°F) [0x1B] (Package)
      Power 0 22.07 W (Package)
      Power 1 n.a. (IA Cores)
      Power 3 n.a. (Uncore)
      Power 4 13.45 W (DRAM)
      Voltage 0 0.70 Volts (VID)
      Voltage 1 +0.00 Volts (IA Offset)
      Voltage 2 +0.00 Volts (GT Offset)
      Voltage 3 +0.00 Volts (LLC/Ring Offset)
      Voltage 4 +0.00 Volts (System Agent Offset)
      Processor 2 ID = 1
      CPUID 6.F.2
      Extended CPUID 6.3F
      Core Stepping M0
      Technology 22 nm
      Tjmax 80.0 °C
      FID/VID Control yes
      Max turbo ratio 28x
      Max Power 290 Watts
      Min Power 69 Watts
      O/C bins none
      Ratio 1 core 38x
      Ratio 2 cores 38x
      Ratio 3 cores 36x
      Ratio 4 cores 35x
      Ratio 5 cores 34x
      Ratio 6 cores 33x
      Ratio 7 cores 32x
      Ratio 8 cores 31x
      Ratio 9 cores 30x
      Ratio 10 cores 29x
      Ratio 11 cores 28x
      Ratio 12 cores 28x
      Ratio 13 cores 28x
      Ratio 14 cores 28x
      Ratio 15 cores 28x
      Ratio 16 cores 28x
      Ratio 17 cores 28x
      Ratio 18 cores 28x
      TSC 2294.7 MHz
      APERF 1197.2 MHz
      MPERF 2294.6 MHz
      Temperature 17 54°C (129°F) [0x1A] (Package)
      Power 16 21.43 W (Package)
      Power 17 n.a. (IA Cores)
      Power 19 n.a. (Uncore)
      Power 20 12.70 W (DRAM)
      Voltage 16 0.69 Volts (VID)
      Voltage 17 +0.00 Volts (IA Offset)
      Voltage 18 +0.00 Volts (GT Offset)
      Voltage 19 +0.00 Volts (LLC/Ring Offset)
      Voltage 20 +0.00 Volts (System Agent Offset)
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #33
        Back Burner is showing 32 cores
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #34
          It seems that CINBENCHMARCH is using 72 cores.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Is it a 3DS MAX limitation? I have Windows 10 Pro, however, I read several posts over the past several days that said you don't need more than Pro to see more than one processor. This post implies that it is once again a limitation with 3DS MAX. Is anyone successfully using Windows 10 Pro with 2 processors over 36 cores?
            http://area.autodesk.com/blogs/maxst...ds-max-support
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #36
              It's a windows limitation but can be accounted for. You can get around it with the following...http://forums.chaosgroup.com/showthr...756#post667756
              • #37
                I have already tried that, but it didn't seem to matter. Also, the thread talks about nightlies, however, that's an old post and I am running the latest V-Ray.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #38
                  You entered it wrong. The variable should be "VRAY_USE_THREAD_AFFINITY" and it's value should be set to "1" (no quotes).
                  EDIT: It's now included in the stable releases, no nightly required but you do still need to set the variable AFAIK.
                  • #39
                    Okay, I see the (no quotes), but I see two sets of quotes. Which set of quotes is omitted?
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #40
                      all the quotes should be omitted
                      • #41
                        Hello guys,
                        I'm not sure if I must post this here but I have a core/thread problem. Multithreading is enabled in the BIOS, If i disable it Ihave 6 core and 6 thread in CPU-Z. What does this mean?
                        Laurent
                        • #42
                          Sorry I have already solved my pbl.
                          thx
                          Laurent
