Highlight Hover
  • Highlight Hover
    The MAX 2016 highlighting of elements when you hover is absolutely annoying. Do you guys turn it off, or are you finding it useful? How do you turn it off?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    Is there a way to make the highlighting stroke thinner? I like it in theory but it is so thick it is intrusive.
      I found out how to turn it off, but I can't imagine someone liking it. Maybe, for a small scene, but anything else is so good.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I like it actually, it shows what you're going to select. If you have multiple elements overlappnig and you want to isolate the one completely obscured by others I use the TAB key to highlight the correct one, then click to select.
        A.
        www.digitaltwins.be
          It could cause a seizure with all this blinking lights.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            You can also adjust the color, if you dont want it to pop out so much.
              good to know, I'll check it out, thanks!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I kind of liked the fill option rather than the outline as it seemed far less annoying lol and used it for a while but shut it off a couple months ago and haven't used it since.
                Cheers,
                -dave
                ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                  The blinking is more apparent when snap is activated. That might be the cause. I turn snap only on when I'm about to need it.
                  A.
                  www.digitaltwins.be
                    I might give it another chance.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      set the colors to something more subtle, its a very useful feature and can easily be toggled on and off with Alt+J
