Stone Wall
  • Stone Wall
    Hey guys,
    I need to create this kind of wall.
    https://www.ecooutdoor.com.au/produc...ls/feathertop/
    https://dp8rc05itw07.cloudfront.net/...Feathertop.jpg
    Any ideas?
    Stan
    3LP Team
    Modelling
    floor generator, https://cg-source.com/floorgenerator.php
    convert to Editable Poly
    Tesselate, (in poly options)
    Noise modifier, very subtle, only in the desired axis only
    Texture maps
    Your image in photoshop.
    Slice tool - will allow you to make mini images based on your selections
    Save For Web - saves all the small images at the same time
    Shader
    You could use the VrayMultitex or the MultiTextureMap,
    Alain Blanchette
    www.pixistudio.com
      Railclone is your friend
      Kind Regards,
      Morne
        Yes, something like that would be easy in Railclone. Actually, I think I saw someone share a style very similar to that.
        Originally posted by 3LP View Post
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Go railclone mate, just did one with it. Create 5-6 different stones whatever the way you want (can be very high poly) then use Railclone to randomize them. Slightly random offset them with to get the wall effect you're looking for.
          Adaptive mode can be tricky if you your pieces have different length and need to be randomized. So you can compose your segments in RC so that, once composed, length is always the same.
          http://www.3dna.be
            Well that's the tricky bit a ran into and that's why I thought I'd come and ask here
            I guess I'll have to give it a second look next time, I found my way by using one of the pre-modelled stonewalls from 3dsky
            Cheers
            Stan
            3LP Team
