Corona to Vray material converter???
  • Corona to Vray material converter???
    Hi guys,
    such as corona has this option, do you knwo any plugin or script that would convert corona materials to vray.
    At least some basic structure???
    Vlado,
    do you plan for such utility in vray?
    Cheers
    M
    Martin
    http://www.pixelbox.cz
    found this:
    http://www.3dstudio.nl/webshop/produ...rial-converter
    anyone using it? is it reliable?
    Martin
      The regular V-Ray scene converter available from the viewport right-click menu can do basic conversion of Corona materials, lights and maps to V-Ray ones.
        we tried that but it is failing to do so unfortunatelly
Name:	corona material conversion.jpg
        its maxes multisubobject material with 5 corona materials within it
        i can see the multisubobject but thats where it stops working...every corona material shows missgin DLL
        Martin
          Salut je ne sais plus où je l'ai trouvé :
          made by Alexander Yakushev (iCube)
          -- Based on 'Corona materail converter' script by Martin Geupel
          mais il fonctionne pas trop mal.
          GHiOM = Guillaume Gaillard
          freelance 3D artist
          www.ghiom.com
            thank you very much!!!!
            will try this and let you guys knwo how it went!
            Martin
              Sorry, i'm tired today, don't know why i've wrote in french
              So it's work, not perfect but it's work.
              Blended corona are not change to vrayblend but others things works from my last try .
              freelance 3D artist
              www.ghiom.com
                so i tried it with the file i needed to convert and it didnt work.
                so maybe there is a bug in that particular model.
                Will try it on some others and leave info here
                Thanks a lot though Ghiom!
                Martin
                  Try Joep's script. The video looked pretty good to me
                  Kind Regards,
                  Morne
                    Hi Morne, u meant the one i posted the link for???
                    Martin
                      found this:
                      Yes this one. Havent tried it, but it looks best to me
                      Kind Regards,
                      Morne
                        i does indeed i just wanted to know if anyone is using it before i invest in this.
                        Last year weve invested over 1000 EUR into SW thats either malfunctioning, not working or abandoned
                        '...one of them being FUME btw...SW which i completely hate...and its support)
                        Want to reduce the risks this year
                        BUt its likely we buy it anyways
                        Martin
                          Joep seems like a nice guy. If you find any issues just let him know and I'm sure he'll sort it out.
                          Kind Regards,
                          Morne
                            Thanks Morne, will buy it this week at some point and let you knwo how it works
                            Martin
                            • #15
                              Link seems to be down.
                              David Anderson
                              www.DavidAnderson.tv
                              Software:
                              Windows 10 Pro
                              3ds Max 2024.2.1 Update
                              V-Ray GPU 6 Update 2.1
                              Hardware:
                              Puget Systems
                              TRX40 EATX
                              AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
                              2X NVIDIA GeForce RTX 3090
                              128GB RAM
