Corona to Vray material converter???
  • #16
    Originally posted by Streetwise View Post
    Link seems to be down.
    The whole http://www.3dstudio.nl/ site seems to be down. maybe they're busy with an update of the site... Ask Joep in the morning
    Kind Regards,
    Morne
    • #17
      I bought that script a couple of weeks ago and although I can't say I've tested it extensively it does not appear to work at all. I've tried converting scenes with Arch&Design Materials into Vray and they are still Arch&Design afterwards. Same thing converting from Corona to Vray if I remember correctly, I lost interest very fast.
      • #18
        I found a link for it somewhere else, and like you, I couldn't get it to work either. What I discovered is that I needed to install the trial version of Corona 1.4 first, then open the Corona scene and run the converter from there. Then it worked. I saved the scene back out as V-Ray and was able to import stuff from it with no issues. Maybe that workflow is just assumed, but for me, I thought I could do it without needing Corona installed.
        David Anderson
        www.DavidAnderson.tv
        Software:
        Windows 10 Pro
        3ds Max 2024.2.1 Update
        V-Ray GPU 6 Update 2.1
        Hardware:
        Puget Systems
        TRX40 EATX
        AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
        2X NVIDIA GeForce RTX 3090
        128GB RAM
        • #19
          Yes, I would have thought it is obvious, but for 3ds Max to read the materials at all, the respective plugin needs to be loaded.
          • #20
            I have both Vray and Corona installed, and Arch&Design is by default I would assume.
            • #21
              Ingot the script from Joep and its still under works, currently its not working well so just be patient i am sure they will make it wort to certain extent ��
              Martin
              http://www.pixelbox.cz
              • #22
                The regular V-Ray scene converter available from the viewport right-click menu can do basic conversion of Corona materials, lights and maps to V-Ray ones.
                When we run the VRay Scene Converter the scene still has Corona Bitmaps left in. Is that on your radar to fix?
                Set V-Ray class properties en masse with the VMC script
                Follow me for script updates: @ollyspolys
                • #23
                  Also CoronaLayeredMtl & CoronaRoundedEdges...
