Of what use are Split Scan Lines in V-Ray?
  • Of what use are Split Scan Lines in V-Ray?
    I see that when I submit a job to Network Render, there's a checkbox for "Split Scan Lines". Being that V-Ray is bucket based, what is SSL, and why would I use it?
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    I think it helps with RAM. Each machine gets a smaller chunk to chew on.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      splits the entire image up.
      a 1000 x 1000 px image with 10 lines, goes to 10 machines as 10 seperate 1000 x 100 px renders that get attached together at the end. comes from an age before distributed rendering but is still very useful.
        Any advantages to managing jobs from a team perspective? I have a client who is trying to figure out how to manage several artists, but yet have control over the queue. They are concerned with any DR failures and having to check node logs, etc. I'm pretty sure that you can have multiple instances of Monitor running and check any errors right from that unless I'm missing something.
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          yes. you have the ability to change the priority of a job mid way. that means that each machine is taking on 1/40th or whatever of the job (even if you only have 5 machines) and if something urgent comes up another job can jump in front without wasting the work thats already done or having to wait for it to finish.
          you need to pre calculate light caches and irradiance maps if you are doing this btw.
            So if you've got a bunch of production jobs lined up in the queue but want to send something out for a quick test for instance? Is pre-calculating light caches a setting?
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
