Bercon for 2016?
  • Bercon for 2016?
    Hey guys,
    we will make the switch to 2016 soon and I'm gathering all the plugins we need.
    Where could I find a viable version of Bercon for 2016?
    I saw Vlado's version was only up to 2015 : http://help.chaosgroup.com/vray/misc/
    Cheers
    Stan
    Stan
    The latest version (3.04) works with 2016. Dunno about 2017
    http://www.ylilammi.com/2013/09/berconmaps/
    - Geoff
      Great thanks mate
      Is it better to use that one or Vlado's one?
      Stan
        Not sure, but that's the one that I use. And higher numbers always means better software, right?
        - Geoff
          I think I saw a BerconMaps_2017_64.dlt on the github page.
          But I don't have 2017 installed yet, so try for yourself
          mekene
            Are the Berkon maps available as a Vray plugin for Maya? They look pretty awesome.
              max 2017 version:
              http://www.maxplugins.de/r2017_files...04_Max2017.zip
                Some of them and in a limited form. Go to Create > V-Ray > Create from V-Ray plugin > Texture > BerconDistortionTex, BerconGradTex, BerconNoiseTex, BerconTileTex, BerconWoodTex. We have not tested them extensively though.
                  That's very interesting Vlado, is there any plans to bring the same list of material plugins to max, so we could make a noiseMayaTex in max as well?
                  Is there any way in Maya to list all these intercompatible shaders in the HyperShade rather than having to go through the Create menu each time?
                  Maxscript made easy....
                  davewortley.wordpress.com
                  Follow me here:
                  facebook.com/MaxMadeEasy
                  If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
                    You can declare them in the shaders/desc.txt file (or another .txt file in the same folder) and V-Ray can generate the HyperShade nodes for you. It's a bit of work though, and most likely you will also want to do custom AE templates (and, in Maya 2016, Node Editor templates) for a nicer UI...
                      With the various different versions of vray available for max, maya, nuke and katana are you thinking of doing some kind of vray noise which would render consistently across all platforms or are you thinking of taking on bercon fully?
                        I like this idea. Standardised procedurals across all the apps would be awesome. Noise, Mix, Tiles, Wave, Checker, Gradient.
                        Follow me here:
                          As far as I know they already have that in the VrMat Editor. I think one of the support people said that it is possible to integrate these into the host application. Would be nice!
