Forest Pro Broken
  • Forest Pro Broken
    I posted this on the ItooSoft forum, but it usually takes them a day to reply. I have a scene that has Forest Pro objects, however, they will not render. No error or warning. I deleted and rebuilt, but nothing. I opened a blank scene and all worked fine. I have come across this before, but building the FP again solved it. This time, no such luck. Deadline is looming, so I need a fix right away.
    https://files.acrobat.com/a/preview/...e-445ca062b8cc
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I've had the situation where a surface I was putting plants on had the normals flipped. FP would not work (as you would expect) until the surface faces where pointing skyward. Would this be the case with your scene? Are you using surfaces or spline areas? Or both?
      It seems to be an issue with your cameras.
      I have almost narrowed it down....
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        It wouldn't be the normals because I have rendered this scene out successfully a dozen times.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Well, that is interesting. How can the cameras effect FP?
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Yes I can confirm it is the cameras.
            If you change the physical cameras to be standard max cameras Forestpack renders.
            Seems like a bug in forestpack....
            Chris Jackson
            Shiftmedia
              Ok if you create a VRayphysicalcamera Forestpack works.
              Use this maxscript - vrayCreateVRayPhysicalCamera()
              Chris Jackson
              Shiftmedia
                I just replaced the cameras with the last known working ones. If that doesn't work, I'll replace them with V-Ray cameras. I'll have to look; can you just change them or do I add new ones? Thanks a ton for the help. I literally wasted all day on this.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Cameras have a huge impact on Forestpack whether it is LOD (Level of detail) to clipping Forest objects to reduce memory.
                  Chris Jackson
                  Shiftmedia
                    Just add new cameras.
                    Chris Jackson
                    Shiftmedia
                      Gotcha. I'll let the guys over there know. Maybe you can get a huge reward
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Script worked perfect. I was confused; I didn't see a V-Ray camera that I could use. And yes, Forest now works! Again, thank you!
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Apparently, it is a known issue in the beta and motion blur.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
