Is the upgrade from windows 7 worth the hassle?
Windows 10 upgrade
Tags: None
Yah the free period is coming to and end... I'd also like to know if there are any pitfalls that come along with win 10?
It's not officially supported by Autodesk yet :P
It's a bit of pain in the Ao. More clicks to do simple tasks, more crap ribbon interface. Win7 interface still buried underneath. Control Panels is hidden away, start-up folder is buried deep.
Nothing I notice is better than in 7, lots are not as good. I think they use the same UI guys as AD and implement 'small annoying things' as features.
Some older AD software is not compatible (due .net version)
Old Opteron CPUs not compatible
Crappy sound drivers (DPC latency issues in the driver that makes everything pop and crackle...although if you run a 'DPC latency checker' this stops the crackles and pops...go figure.)
But apart from the above grips, so far it works...Simon
I need a new signature
Max2017.1 | Vray 3.70.01| win11
ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
I've got no plans to upgrade. Will hold out till Windows 7 totally dies before upgrading my work machine. Why oh why can't Windows 10 have a Windows 7 theme? And by that I mean the xp theme for Windows 7 :PBrendan Coyle | www.brendancoyle.com
did the free upgrade, its nice but very sticky hard to explain and i have issues now with nitrous and old scenes, need to use directx in max, other than that it seems okArchitectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
anyone tried downgrading? is it possible? or would that require a traditional reinstall of win 7? Was told that it might be a good idea to just do the damn upgrade before the 29th, so you get your win 10 license, and then you can revert to win 7 and keep on using that. But still got the free win 10, just in case.
Too much hassle for me right now I think, but it's always nice with a clean install every now and then
Originally posted by tzaar View Postanyone tried downgrading? is it possible? or would that require a traditional reinstall of win 7? Was told that it might be a good idea to just do the damn upgrade before the 29th, so you get your win 10 license, and then you can revert to win 7 and keep on using that. But still got the free win 10, just in case.
Too much hassle for me right now I think, but it's always nice with a clean install every now and thenArchitectural and Product Visualization at MITVIZ
I reinstalled my pc with windows 10, with max 2016 and the new vray 3.4, works really fine untill max was completely reset one morning.... and with reset i mean all the preferences (that are stored in 3dsmax.ini) where gone, and the day's after, max kept on resetting. I have been reading on the autodesk forum and it seems to be a common problem for some users/and not always ... very annoying & very strange .
So maybe someting is wrong in the installation procedure, anyway i am going to reinstall my pc again grrrrrr
I'm happy with w7, not a big fan of w10 interface.....I'm not sure if I will upgrade...
Anyway, I will build a new pc next month with (certainly) W10.
I'll probably try to keep my old pc (w7) as a render node (DR, backburner)
Does it mean it would be better to upgrade my futur "old pc" to keep the same os ? Do I have to expect myself a lot of problem if I have to manage W7 & W10 ?(Sorry for my bad english)
upgraded over a year ago and have not had any issues, it is certainly superior to win7 once you get used to the little differences.WerT
www.dvstudios.com.au
No problems here.Well, a couple small ones, but I wouldn't turn back, even if I had the chance. Now, if it cost something, I would probably still be on Win7Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Upgrading to Windows 10 is pretty painless. I upgraded a workstation from 2009 that was built with with XP Pro and then later upgraded to Windows 7 and then to Windows 10 without any issues.
It took me a bit of time to turn off/remove a lot of little annoying things like animated tiles for apps I'll never use but overall I prefer Windows 10 to Windows 7.Steve Burke
www.burkestudios.com
