Quicktime VR question
  • Quicktime VR question
    I have a client that would like to have more of an interactive experience with an interior scene. They would like to stand in the center of the space and view around. I remember using QTVR years ago. Is anyone using this method or is there something better?
    Thanks......Scott
    Now, it is with goggles, but the same premis.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      QTVR died along time ago... Quicktime itself is on its last leg, and can't die soon enough. Apple stopped developing it for Windows and isn't even releasing patches to fix the security exploits that have turned up recently.
      There are a handful of apps that utilize the browser and CSS 3d transformations to create a superior experience to what QTVR ever gave. Our preference is KRPano...
      http://www.sbpanohost.com/LanePartners/AtriumFinal/
      You can also drop this into a GearVR headset for a more immersive experience. If you want to go even further you can render it stereoscopic and drop it into the Gear headset for real wow factor.
        Lovely example Travis, nicely done!
        Kind Regards,
        Morne
          Thanks Travis.......Awesome example. That's exactly what I am looking for. I have one question, how do you set up the camera and render all the pieces necessary for this type app? Also, this will not be a headset application but a web based app. I found this software http://www.easypano.com/virtual-tour-software.html The one thing I like about it, you can create hotspots and navigate the space.
          Scott
            Scott
            You can also do that with Krpano
              Scott
              I only know KRPano.
              As for setting up scene.... it has likely been covered on the board multiple times so I won't go into much detail. You need a camera that is level, set the resolution to 2x1 ratio, and change the camera to spherical with a FOV override of 360. Not much more complicated than that.
              Build a simple scene.... Maybe a box with a grid on each side. Use that to test before diving into a complicated scene.
