Sigershaders
  • Sigershaders
    Updating now and downloading now!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Update out and downloading now!
    Same here. Finally!
    Kind Regards,
    Morne
      I went through the installer, however, I don't see anything new. Maybe I'll remove the old one first and try again.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        It's very annoying. If you look at the installation files, it says you ALSO need the free siger plugins. There's 4 of them. The point is that its highly unlikely for a 3rd party FARM to have the extra plugins installed.
        Kind Regards,
        Morne
          He says they can run side by side, so yes you need to make either a new link, or uninstall old one
          Kind Regards,
          Morne
            I'll try again this afternoon. There were about a dozen files to download, so I am assuming the installer did what it needed to do with all the other downloads and there wasn't any manual copying needed.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              No that assumption is incorrect. You need to manually copy the scenes folder to C:\VMPPmax
              The "maps4" folder can be anywhere, but you have to specify the path otherwise the maps wont be found.
              But I agree with you, the installer should handle all this automatically
              https://www.sigershop.eu/vmppmax-rg-install/
              UPDATE: apparently Rebus has all the needed free siger plugins
              Kind Regards,
              Morne
                Good to know, thanks!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Followed everything and almost there, but not! A lot of steps so maybe I missed something.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I forgot the last step, which was to license it.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      disappointing...none of those plugins probably work with V-Ray RT.
                      "I have not failed. I've just found 10,000 ways that won't work."
                      Thomas A. Edison
                        Maybe eventually they will. For now, I am excited to start using them in my regular workflow.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          You would like to download in case of each future updating archive in 10GB with setup and Cab files? I think, it's much more convenient to download 0.5GB setup. Maps and scenes it isn't so often updated.
                          Regimantas Valiukas
                          SIGER STUDIO
                          www.sigerstudio.eu
                            You don't understand. We don't want all the files included in 1 file. We want the installer to handle everything, in other words it will take the other files and put them where they need to go and extract them there etc. When its just an update, the installer will only update what is needed.
                            Anyway, so far it seems the real world scale is not working correctly and I think it may be a bug. My display units are mm and scene units m, but when importing for example Bronze Satin, the bump size is 30000mm X 30000mm (30m X 30m)
                            Also, it would be nice to be able to make the thumbnails larger than 200.
                            Kind Regards,
                            Morne
                            • #15
                              Well I was happy for about 5 seconds after the install. Everything looks nice and I thought I would work a bit quicker now. Siger Support was quick to respond, however says in order to make the real world scale work, your scene units and display units should be the same. That's a serious design flaw in my opinion.
                              Kind Regards,
                              Morne
