Max 2017 SP2 is out
  • Max 2017 SP2 is out
    Grab it while it's hot
    https://knowledge.autodesk.com/suppo...-2.html?v=2017
    Kind Regards,
    Morne
    Hot dog! it's like Christmas today! Hopefully, MAX gets better for people and not worse.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      The changelog seems to cover most of the bad ones...
      for example: Things like having Max X 3 open etc is supposedly fixed now
      Kind Regards,
      Morne
        How in the hell could they not have fixed the 'select by material'? I don't mean to complain, but that was one of the biggest things people were bringing up, proving that Autodesk was a bunch if baboons.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          ill wait for SP3 then or completely skip this one...which would will mean i will throw away 50K CZK for this years maintenance subscription :-/
          idiots....this really makes me mad
          Martin
          http://www.pixelbox.cz
            Bobby this is from the AREA forum:
            Yeah - it's official
            And before big rant threads appear everywhere:
            Seems the infamous "Select by Material" not working with Scene Explorer based dialogs bug is still not fixed with that SP Smiley Sad So i'll stick with the legacy "select from scene" dialog hacks quite a bit longer. "Select by Material" works in those legacy dialogs ...
            Martin
              I am fine with an MAXSCRIPT, but come one, listen to your customers!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                The fact that we have to skip a version (which I will more than likely do too) is beyond a joke ! What the hell are we paying for ?
                Regards
                Steve
                My Portfolio
                  Imagine a world where you can make millions to create things that don't work.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    A scene that worked fine with SP1 now isn't bearable in SP2. Is anyone else experiencing this? I was working fine yesterday, upgraded last night and this morning, the viewport is so slow I can't work.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      What version of windows are you on? Windows 10 is hateful with Max.
                      "I have not failed. I've just found 10,000 ways that won't work."
                      Thomas A. Edison
                        Cr@p, I decided to upgrade yesterday when I saw SP2 was out.
                          Yes, Windows 10, but I haven't had an issue until now.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            I just got back from Siggraph and had some good conversations with reps from Intel and BOXX. It appears that Windows 10 does not play well with machines running over 64 threads i.e dual 18 core Xeon's and above. I had issues that would slowly cripple a machine until it becomes unusable with a similar configuration.
                            Take a look at the application and system logs in the event viewer. I bet it's flooded with errors.
                            All of the demos that BOXX was running 3DS MAX 2017 were running windows 7 Pro. Not a Single BOXX machine was on windows 10.
                            Thomas A. Edison
                            • #15
                              I don't have over 64 cores. I checked my logs and there are no errors. I haven't had a single issue until SP2, which I installed yesterday. I am removing it now; I'll see what happens.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
