pattern
  • pattern
    hi all
    I should generates such a pattern? http://c2n.me/3Gx8su0.png
    it's quite difficult, thought it would be easier. how would you make it? any good ideas?
    thanks a lot for suggestions.
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    I would use a particle system of cubes, then use random rotations with rotation limits
    Just looked at it again, the shapes are not just cubes, so just randomise the shapes a bit as well.
    Gavin Jeoffreys
    Freelance 3D Generalist
      Did a quick test if it helps.
      Gavin Jeoffreys
        i really need to look into particles, one area of max i know nothing about, looks nice
        Architectural and Product Visualization at MITVIZ
        http://www.mitviz.com/
        http://mitviz.blogspot.com/
        http://www.flickr.com/photos/shawnmitford/
        i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
          Looks more like several planes with noises stuck together?
          You could create a plane with enough subdivs, add a noise modifier with XYZ stregth. Then copy the plane and change the seed.
          Rens Heeren
          Generalist
          WEBSITE - IMDB - LINKEDIN - OSL SHADERS
