wicker hell!!!
  • wicker hell!!!
    Does anyone have any ideas how to model such thing ALL IN GEOMETRY, fast? Are there any trick to do without too much donkey polygon pushing pain?
    Luke Szeflinski
    :: www.lukx.com cgi
    I once saw a displacement map that did it; I'll look to see if it is something that I have.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      Yeah but as I said it has to be pure geometry, no displacement
      Luke Szeflinski
      :: www.lukx.com cgi
        Maybe bit of railclone to create some wicker panels which you can then FFD around a bit?
          Yeah i'm trying that but there are problems with matching intersections. Well I guess it's donkey work solution is the only way
          Luke Szeflinski
          :: www.lukx.com cgi
            Would recommend vray pattern. Does it all in geo at render time. The only fiddly bit is creating the weave sample - not sure if it supports GPU though... in so many ways it would be brilliant to actually have it as part of VRAY.
              no go also, as it needs to be later on possible to render with different engines
              Luke Szeflinski
              :: www.lukx.com cgi
                https://1drv.ms/i/s!AhVhYJcmZb21tQpO9-KQeXU5Pcpz
                Here's a picture of a wool weave done with vray pattern - vray fur was applied to the mesh
                  This may help
                  http://www.scriptspot.com/3ds-max/mcg/mcg-simpleweave
                  Gavin Jeoffreys
                  Freelance 3D Generalist
                    In all caps, too
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      This works pretty well.
                      http://cganimator.com/mcg-quadscatter-1-5/
                      Neal Biggs
                      3D Generalist | Freelance | Founder | Big5 Studio
                      http://big5studio.com/
                      3ds Max 2022 - V-Ray5 Update 2.2
                        that would be simple spline modeling but MCG simple weave and quad scatter look awesome!
                        Architectural and Product Visualization at MITVIZ
                        http://www.mitviz.com/
                        http://mitviz.blogspot.com/
                        http://www.flickr.com/photos/shawnmitford/
                        i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
                          I would use the China or Russia plugin. No sense in spending time modeling that if it can't be done in less than an hour.
                            Maybe AutoModeller?
                            http://www.automodeller.com/index.html
                            • #15
                              what about simple Patch Deform?
Name:	patch deform .JPG
                              Marcin Piotrowski
                              youtube
