Any ideas for modelling this?
  • Any ideas for modelling this?
    Feel like there should be some procedural method to get some bits like this? Which i can then scatter with FPP?
    Anyone done something like this before?
    grow fx maybe ?
    Luke Szeflinski
    :: www.lukx.com cgi
      Most likely.. but I don't have it! Need to do in Max if possible..
        well thats almost a textbook classic l-system fractal.. iirc there is at least one script to produce them knocking around somewhere..
          Blur had a l system plugin.
          Haven't checked it but here is a link
          http://www.maxplugins.de/max2016.php....0&sort=Author
          Gavin Jeoffreys
          Freelance 3D Generalist
            That L system mentioned sent to a few promising looking things.
            Ive just tried that blur plugin, but seems to just make a spiral? Or more likely I don't get how to use it properly
              I also found this one, but can't really get it to do what I want (lack of user understanding im sure)
              https://github.com/CreativeTools/ct-l-system
                what about AEC Extended foliage object from 3ds max?
                Euphorbia model looks similar. endless variations for free.
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
                  i think thats your solution right there
                  EDIT: although the control is rather limited and it cannot do anything like the density of some of the parts of the original example
                    Yes, this should do nicely. Cant even remember the last time I looked in that section.
                    Thanks!
                      if you need something more than look for Arbaro - free plant modeling tool. should still be around.
                      Marcin Piotrowski
                      youtube
                      CGI OCIO config 04
                        Tis indeed https://sourceforge.net/projects/arbaro/
                        and looks quite handy
                          Guess you could use GrowFX. Even if you don't use it that much, it's totally worth the price. I'd also try making it with particles (and mesh them with splines).
                            i shared this with a 3Ds Max group on Facebook to see what ideas they had https://www.facebook.com/groups/1611269852441897/
                            • #15
                              Cool, some clever ideas there.
                              Im really interested as to how one would implement this using maxscript:
                              http://benice-equation.blogspot.co.u...ctal-tree.html
