Show map in viewport problem - max 7
  • Show map in viewport problem - max 7
    Can anyone help me, I have just got a copy of 3D Max 7 at work and when I toggle the show map in viewport in the materials panel, it doesn't display the map int e viewport.
    It renders OK but obviously in order to map correctly I need to see it. Has anyone else have this problem or have I turned something off my mistake.
    It works on other copies of max so my guess is I have toggeled something
    Any help please
    you may have to UVW Map the object ... look in the max help.
    Natty
    http://www.rendertime.co.uk
      I have its not that, I have it on 2 machines same scene on will not display maps
        this is a very simple question ...and can only be one of two things... either you havent pressed show map button, or you havent mapped your object properly.
        Natty
          I really have I am looking at it right now on two different machines. I realise what you are saying that's why I am so confused
            Also when you toggle the show map in viewport, the object changes to a lighter tone, it renders fine just will not display
              MMM .... odd .. can you show a screen shot ?
              Natty
                How can I post and image?
                  email me..
                  Natty
                    Sorry about this where can I find you email address?
                      Have sent it
                        HI Natty
                        Have just re-installed it and it have fixed the problem. Thanks for you help
                        Mark
                          installed max again ? .... wow ... bit drastic ..
                          Natty
                            I spent about 1 hour nad a half messing about with it, I really have no idea what had happened
