seen this citroen C4 animation?
  • seen this citroen C4 animation?
    http://www.spyfilms.com/whatsNew.html
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
    Yep! Very impressive I must say. Rendered in Lightwave, if I
    remember correctly. Man, it's must have been quite a task to think how to
    take the car apart and make it move like it does!
    Mare
      Yeah...its pretty damn good...the lighting and materials are perfect.
      -----Dwayne D. Ellis-----
        Hey ! yep really nice !
        Here is a link where they explain how they did it....
        http://www.luxology.com/article/113004_1/1.aspx
        They used This modeling software so called Modo and rendering was done in Lightwave.
        The C4 was scan by the compagny Gentle Giant
        http://www.gentlegiantstudios.com/
        and that the Post podruction compagny The Embassy Visual Effects Inc.
        http://www.theembassyvfx.com/
        Done by the director Neill Blomkamp
        On this link :
        http://analogik.com/mm_rev_tetra.asp
        you can find an other work of The Embassy/Neill Blomkamp, Tetra Vaal.
          i just love that comercial. they did an awsome job making sure the clumsy car parts did not overlap with their mocap.
            I wonder what software/ technique they used to get those glows only on the overbright areas. Is this just an effect of using HDR in compositing or do they have to render out an unclamped pass and use a special plugin? I haven't been able to recreate this with the standard filters in Combustion.
            --Jon
              Modo is a great modeling tool. I Have no idea how to model in subd's but I started using it, and the workflow is great. The only probelm is that it doesnt export 3ds, or max. you have to get some plugin someone wrote. How does max support sub d modeling? Does it have suport for ngons?
              Modo's interface is awsome too, you can 100% customize everything. Its entirely script based. You can make new images, and make the interface look like what ever your want, and the scripts are perl, so if you have perl experience, you can start wrting complex scripts in no time.
                yep..just great these glows...
                i can imagine they render a pass and then put either a blur or a glow filter on top of it...
                but the Filter Glow in combustion is working really gret also !!
                It's just about finetuning things...i guess
                  yeah the thing that struck me the most the is the materials and lighting integration.....it's just right .......and those glows and reflections have just the right intensity......
                  seems like all their compositing work is very well done...
                  paul.
