Importing DWG with dashed lines in 3ds Max and retain the dashed lines?
  • Importing DWG with dashed lines in 3ds Max and retain the dashed lines?
    Is there a way to import DWG in 3ds Max and retain the look of dashed lines? They appear as solid lines after importing.
    Thanks in advance!
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    you need to do this in autocad.
    use WMFOUT to export the line(s) and WMFIN to import it back as a block and explode it. that?s it.
    Surrealismo
    https://www.facebook.com/surrrealismo
      Thanks for the suggestion but it didn't work. After importing with WMFIN the dashed lines got converted to continuous lines. Exploding didn't help either.
      Aleksandar Mitov
      96GB DDR5
        that?s strange. I do this all the time
        Surrealismo
