So I should be able to post in the regular subtopics but cant for some reason...
So I have 3DS Max 2019 with VRay Next with 3 extra render nodes...
My workstation is a slightly overclocked i7 runs about 3.8 gHz with 10 true cores windows 8.1 64 g ddr4 ram.
My Render nodes are 3x older dual Xeon HP z800 workstations that run 6 true cores x 2 (dual processor), windows 10, with 64 g ddr3 ram...hyperthreading enabled runs at about 3.3 ghz- so 12 true cores
So I would expect that the workstation and the node would render at close to the same speeds...
But both with my scenes and with the vraybenchmark app... the workstation i7 renders about twice as fast as the dual xeon render nodes... The benchmark app sees all of the cores as it should but the speed difference doesn't add up to me...
Any thoughts.... and why cant I post in the regular subtopics
